Export routes from Basecamp to XT via smartphone
wingrider.steve
Post by wingrider.steve »
I have Garmin Drive installed on my phone and it connects to my XT without problem.
Ever since the last update on the XT I can't get routes to transfer from my phone to the XT, keep getting and error message.
Any ideas how I can resolve this?
simoncrewe
Has liked: 47 times
Been liked: 38 times
Re: Export routes from Basecamp to XT via smartphone
Post by simoncrewe »
wingrider.steve wrote: Mon Jun 21, 2021 1:44 pm I have Garmin Drive installed on my phone and it connects to my XT without problem.
I think you will first need to export the Basecamp data to Garmin Explore & then the Drive app syncs that to explore on the XT unit itself.
wingrider.steve
I didn't need to do that before and in any case when I try to setup Explore the Zumo XT is shown as not compatible with it?
wingrider.steve
Fingers crossed I've sorted it!
I checked my phone and there was another update available for Garmin Drive, I ran the update and so far everything seems back to normal.
Nice of Garmin to correct the previous update so quickly.
Scsiboy
Australia
Post by Scsiboy »
Hi,
I also received an error when trying to export my route from Garmin Basecamp on my Mac.
As you stated, I also had no issue until the recent update to the drive app on IOS (iphone)
The error message I received on the ZumoXt screen is “failed to import new trips”
Is this the error you were receiving when you encountered the problem ?
Could you let us know which version of Garmin Drive App on your device you are now using that seems to of corrected the error?
Are you using iphone IOS or Android ?
Thanks
An9dy
Post by An9dy »
I'm not using BaseCamp.
But to transfer gpx route files from my Android mobile phone to Zumo XT, you MUST update GarminDriveApp.
Download/update GarminDriveApp to version 4.16.26 on your phone.
Previous versions caused Garmin Drive to crash when attemting to share the gpx route file.
[I can't comment for IOS devices]
Good luck
