Power Supply Wiring
teammotobuild
- Been liked: 1 time
Power Supply Wiring
Hello...is the little plastic box on the power supply of the zumo xt anything more than a collector of the power and ground wire? I'd like to shorten it way up so that the mount becomes easily removable like I did with my Montana mount. Using the same SAE trickle charger connection up by the handle bars and a ram mount I can remove the whole thing and transfer between bikes. Just want to make sure I'm not cutting a suppressor or something that's vital. Thanks!
- IMG_7996.jpg (207.04 KiB) Viewed 3689 times
- IMG_7995.jpg (234.38 KiB) Viewed 3689 times
- Site Admin
- Has liked: 438 times
- Been liked: 266 times
Re: Power Supply Wiring
The black box is a converter it converts 12v to 5v
The lead from that to the connector is NOT just two wires I believe its coax cable so not easy to put a connector on it
teammotobuild
What are people doing for a quick removal of the mount for these? The montana had several wires that were more for plugging in audio etc...5 wires maybe...just connected the red/black and it works great. The zumo xt is starting to look like a return with all the extra steps to use it...not showing up on a mac desktop like all the garmins I've had prior. The mount stuck on the bike all the time is a deal breaker. Need an easy off solution.
The Zumo mounts are is designed to be permanently fixed on the bike, and the wiring is direct to the battery using the lead with the built in 12v to 5v convertor.
The only ways that I can think of to make the mount easily detachable are:
* permanently mount the harness and put in an exposed waterproof connector in the 5v side
* is bundle the wires neatly onto the mount and have a handy 12v connector close to the mount.
Dont be tempted to use the Usb connector for power. The car mount uses this, but the vibrations on a bike will likely damage it - not to mention leaving the connector open to the elements.
colirv
- Has liked: 66 times
- Been liked: 64 times
- Contact:
That's what I would do, using a waterproof in-line connector.jfheath wrote: Tue Dec 14, 2021 5:59 am bundle the wires neatly onto the mount and have a handy 12v connector close to the mount.
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
Do a search on this thread https://advrider.com/f/threads/garmin-zumo-xt.1431553/ a number of the guys have modified the power lead to switch the unit between multiple motorcycles. As other people have mentioned the lead has a foil liner / coax so can be tricky to cut & solder.teammotobuild wrote: Mon Dec 13, 2021 10:16 pm Hello...is the little plastic box on the power supply of the zumo xt anything more than a collector of the power and ground wire? I'd like to shorten it way up so that the mount becomes easily removable like I did with my Montana mount. Using the same SAE trickle charger connection up by the handle bars and a ram mount I can remove the whole thing and transfer between bikes. Just want to make sure I'm not cutting a suppressor or something that's vital. Thanks!
