Zumo XT not navigating after update
Alanopilota
Post by Alanopilota »
Hi,
I have recently updated my XT, both the software and map updates.
It won’t navigate to any destination anymore, it was fine a few days ago before the update.
I didn’t connect it to a laptop but just connected it to my home Wi-Fi
Anyone had this problem ?
Has liked: 424 times
Been liked: 240 times
Re: Zumo XT not navigating after update
Hi and welcome to the forum
What do you mean it won't navigate to your destination?
As in the destination is wrong or the navigation is not working
Alanopilota
If I ride the bike the XT works fine as a moving map display but, any attempt to enter a destination and ride using a route, is met with a “cannot calculate route” message
Alanopilota
The Garmin manual just says do the map update again,making sure it is not interrupted.
What it does NOT say is how you actually do that when the XT thinks it’s software and maps are up to date. There doesn’t appear to be a way of re-updating it.
Has liked: 372 times
Been liked: 383 times
Express offers a map reinstall as one of the options
Alanopilota
Does that have to be done by connecting to a laptop ?
Fxwheels
Has liked: 30 times
Been liked: 30 times
Post by Fxwheels »
I'm always very cautious about updates. Had different problems after it on the previous navs.
If it does what you need and there's no new useful functions added - don't just update it.
Maybe you should reset the unit if it doesn't help, call Garmin support for reinstalling the maps.
Alanopilota
I updated it as I was in central London with a lot of new 20mph zones which mine was still saying were 30mph……wish I had left it as it was
Most of the time with issues like this a factory reset sorts it out
I would also try connecting it to a computer and using garmin express to re install the update
Alanopilota
Stu, thanks.
My son has been helping with his laptop and Garmin express but…..we still don’t know how to do the full factory reset…..do you know how ?
