Factory Reset, Right Corner - Power On not working?
larsras
Denmark
Post by larsras »
Hi
Can someone confirm this method is not working on an XT? (it works on my 390).
The XT is completely garbled with a mix of maps, probably due to an error during update.
Soft reset or reset from the menu systems does not do any difference on the XT.
br Lars
simoncrewe
Has liked: 47 times
Been liked: 38 times
Re: Factory Reset, Right Corner - Power On not working?
Post by simoncrewe »
larsras
Denmark
Post by larsras »
Thanks, but was already tried. Does not delete maps.
Has liked: 378 times
Been liked: 384 times
No reset deletes maps
simoncrewe
Has liked: 47 times
larsras wrote: Mon Aug 08, 2022 7:20 pm Hi
br Lars
Lars, I think you may have confused us all! Your original post did not mention deleting maps, as 'sussamab' pointed out a factory reset never deletes maps.
If you want to delete maps off the unit you will need to do that with the XT connected to your PC/Mac. Just be careful what you delete, as it is easy to introduce problems whilst deleting files.
To delete maps try GMTK https://www.javawa.nl/gmtk_en.html
