Imported Trips Not in Sequential Order
I have several routes listed on my 595LM under Imported Trips that I would like to change the order they're in manually as well as sequential. Is that possible? Thanks
- Has liked: 110 times
- Been liked: 70 times
Re: Imported Trips Not in Sequential Order
They might be sorted by date / time of the start of the trip in your 590.
- Has liked: 108 times
- Been liked: 99 times
They get sorted by route name, not file name, at least on my 660. So the trick is to go in and put numbers in the actual route name in the GPX file. Only takes a minute or two using a plain text editor. Look for the following tags in the GPX file: <rte> then <name>. Like this:
<rte>
<name>1.Catskills Shawangunks Ride</name>
Thanks for the help...... I jump in and try in the GPX file like danham stated. Thanks again.Oop North John wrote: ↑Sun Oct 09, 2022 12:26 pm They might be sorted by date / time of the start of the trip in your 590.
