XT and Basecamp on Mac book pro.
paulo464
Post by paulo464 »
Aup All. I am competent user of basecamp for many years with Montana. When I connect my zumoXT to basecamp, it does not see the device.
The device does show up on Garmin express so the cable & computer is recognising it.
I am trying to send some OSM Topo maps to the device but again Garmin Mapinstall does not see the device!!
I have tried connecting/ disconnecting , powering off and on both device and computer with no joy......
Can anyone help me out here????
Cheers.
PC.
H2R
Been liked: 3 times
Re: XT and Basecamp on Mac book pro.
Post by H2R »
Paulo464,
Does this post on the Garmin forum help any? It sounds similar to what you describe.
https://forums.garmin.com/apps-software ... 62#1231262
-Jim
clayto464
France
Post by clayto464 »
Thanks Jim, BC did. eventually recognise XT but then moved at glacial speed so no use really. I am now trying through an SD card, been on it two days and still no luck, cant seem to get the SD card to show up on the XT......
I'm confused. Are @paulo464 and @clayto464 the same person ?
Daibach
Post by Daibach »
Thanks Jim and everyone who posted the solution to Zumo XT not being recognized by Basecamp. Finding out about and turning off the automatic Garmin Express start up did the trick for me.
Exrm193
Post by Exrm193 »
Download this app from the App Store...That will solve your problems
Screenshot 2023-04-10 at 19.02.46.png (67.17 KiB) Viewed 12822 times
Exrm193
Post by Exrm193 »
As far as I'm aware, you can only have 1 x programme using the XT...Try closing everything else and just use 1 programme at a time.
