Supported?
Woody
Has liked: 13 times
Been liked: 3 times
Supported?
Post by Woody »
I have dug out an old Zumo 550 and just tried an update but it seems Garmin has stopped supporting the unit.
Anyone have any info?
Has liked: 371 times
Been liked: 380 times
Re: Supported?
What makes you say that? It's discontinued but you can still update maps etc
Has liked: 108 times
Been liked: 250 times
Re: Supported?
Perhaps if you describe how you "tried an update".
carolinarider09
Has liked: 29 times
Been liked: 39 times
Re: Supported?
Post by carolinarider09 »
Also, not sure but could the "lifetime" updates have paused because of lack of use.
I havd a 550, I have not updated the maps this year because when I did the street names were no longer fully shown. Lower case letters were used as is common in English were as before the street names were all Caps.
Otherwise the map updates work.
Dunny
Australia
Re: Supported?
Post by Dunny »
Hi guys,
I have had my 550 for many years but not used for about 4 years. I got onto the Garmin site to update my old ANZ NT2012 maps and this was the greeting I got on the web site.
In accordance with the Lifetime Maps and Maps Terms and Conditions, map updates and/or Downloadable Content (DLC) are no longer available to download or purchase and cannot be activated and/or associated with the Garmin devices listed in Map Updates and Downloadable Content No Longer Available to Download or Purchase.
This is due to these devices not having sufficient memory capacity and other required technical capabilities to utilize current map data.
:o
Surely not! Any advise?
Zumek
Has liked: 7 times
Been liked: 18 times
Poland
Re: Supported?
Post by Zumek »
Use alternative maps for your area, for example https://alternativaslibres.org/en/index.php
Has liked: 68 times
Been liked: 180 times
Re: Supported?
Links to more OSM maps here: https://wiki.openstreetmap.org/wiki/OSM ... n/Download
Color schemes and detail levels vary by source, so you might want to try a few different ones.
Of the OSM maps I've experimented with, the ones from OpenMapchest.org seem to suit me best:https://www.openmapchest.org/maps/austr ... d-oceania/
Dunny
Australia
Re: Supported?
Post by Dunny »
Hi Guys,
I downloaded a version of latest 2023 Australian and NZ maps to a SD card. Can someone please remind me how to send maps from SD in unit to Mapsource, as it only shows the old version in the utilities drop down. TIA
Re: Supported?
You can't. BaseCamp can read maps from a sd card or device but MapSource cannot. You need to use Express to install the map to your PC.
Dunny
Australia
Re: Supported?
Post by Dunny »
OK. Thanks Sussamb.
That is a shame as Mapsource works great.
