Have the speed camera warnings been taken away from us and moved to a subscription service?
Mine had been working fine but since a recent update (via Express) they don't seem to be working any more and a friend has reported the same.
Speed Cameras
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
Re: Speed Cameras
In the UK they have always been included in the price of the XT, although they show on Garmin Express as aan option that you can purchase.
Re: Speed Cameras
Yeah, that's what I thought. I think seeing them available to buy has spooked my pal when they seem not to be working. I have explained to him that there is every chance that Garmin have broken then with the update
Re: Speed Cameras
Just been out for another test run and definitely getting no warnings or signs of the speed cameras, and being in West Yorkshire I don't have to go far to find rows and rows of cameras to try it on
Oh well, good old Garmin
Re: Speed Cameras
An update shouldn't affect cameras already loaded though. You can check if the files are there using Windows Explorer. If the files are there the update may have affected their display, if so try a master reset.
Re: Speed Cameras
Windows explorer would probably need a Windows PC I expect - Mac only for me
The About info on the XT shows cyclops details so I think it's there on the unit, but not sure why the XT is not giving me warnings - that could be down to the XTs system rather than the cyclops data.
I have given it a master reset, always the first thing to try when it's not behaving
Re: Speed Cameras
So, just had a poke around in Garmin Express - clicked on Tools & Content, then Purchased, and there's the option to download Cyclops Europe (I've not purchased this btw)
Downloaded it and now they are working again
