Cannot Load Maps on Boot
Has liked: 432 times
Been liked: 951 times
I have a friend in America who reports:
When I first boot up the XT in the morning for a ride, I almost always get, "Cannot Load Maps".
I've never seen this - has anyone else come across it / found a solution ?
I've asked him to check MyMaps, and untick everything, and then systematically tick each one in turn and reboot to see if it is any one particular map that is causing the problem.
Other than that, I am lost.
Has liked: 147 times
Been liked: 453 times
Re: Cannot Load Maps on Boot
I have never seen "Cannot load maps". His tone indicates that he eventually gets it to work. If so, does he provide any detail about how he gets it working?
If he is using Garmin maps (CN NA NT), is a reinstall via Express worthy of consideration?
Has liked: 381 times
Been liked: 384 times
Sounds like he has multiple maps installed. Which map is causing the message? If a third party map he needs to delete it, if the Garmin CN map then as suggested a reinstall is the first thing to try.
Rofor
Has liked: 171 times
Been liked: 77 times
Austria
Post by Rofor »
Hmmm - maybe exceeding the tile-limit?
Bye, Robert :)
Update.
The message I was given was incorrect.
'Cannot unlock maps' is what it actually says!
Ive directed him to tech support for that one.
Sorry about that folks. Thanks for your thoughts anyway...
Bear
Been liked: 3 times
Post by Bear »
Thanks Bear
I got the impressiont that this was a new unit with software as is. But that might be my assumption and anything could have taken place. Always a good idea to go back to the reset everything / reinstall maps. ALway dangerous to make assumptions.
I'll pass it on.
