Quite happy with the XT, seems to work well, but...
my old garmin had a feature where it showed where you went off route as a sort of dotted line, which was handy to see if you needed to find your way back on route, rather than just using re calculate and trusting to luck, does the xt have this?
Also, I see various mentions of tracks. Now what would be really useful is to be able to save a track of where we have ridden (when not using xt to navigate a route) and saving these tracks for future use, again is this feature available on xt?
if it is possible to do either or both of these, how to set them up, please!
Thanks
