Bluetooth Help needed
Jetfixer
Post by Jetfixer »
I recently switched from a Zumo XT to the new Zumo XT2. I use a Sirius/XM Satellite radio mounted in the "Bluetooth SiriusXM Satellite Radio Vehicle Dock SXBTD1V1". I had no issues pairing this Dock to my previous Zumo XT, but when I try to pair it to the new ZumoXT2, it lists it as a "headset". Obviously, this doesn't work. My guess is that either the Zumo XT2 or the Dock is trying to use the wrong Bluetooth profile. Is there any way to make the Zumo XT2 recognize this dock correctly?
Re: Bluetooth Help needed
Welcome to the forums @Jetfixer. Sorry its a late reply, I was away when you posted it.
Have you made any progress with this ? I would imagine that it is a rare combination of headset, Zumo XT and satellite radio - but there must be similarities, and you have the experience of the XT to fall back on.
Do you still have your XT ?
I am going to suggest a catch all for BT problems.
* make sure that no unwanted devices can pair and grab channels while you are not looking.
* Pair the headset to the Zumo first - make sure the Zumo is paired on your headset as a (second) phone , not as a GPS if that feature is available
* Make sure you can get sound from the Zumo to your headset.
* Turn off headset and GPS. Then restart and make sure that they pair.
Now, if it was a phone, i would then say to pair the phone to the Zumo. The zumo gets your contacts, dialling functions and speech in and out and transfers it to the connected device.
But with a satellite system, I can only guess that it can allow the Zumo to take control by BT
I have zero experience with satellite phones, so ignore anything here that doesn't apply.
My main concern was to reply to an interesting question and to bounce the topic up to the top of the forum list in case anyone else - like me - had missed it !
Has liked: 148 times
Been liked: 139 times
Not sure about the XT2, but I know the XT prefers that functions it doesn't recognize go through your phone. I use a Valentine radar detector and its Bluetooth device will not pair with the XT. It will pair with my iPhone, however, which is paired to the XT, and that becomes the pipeline for radar warnings to be handled by the XT and sent to my Sena helmet speakers.
Jetfixer
Post by Jetfixer »
Thank you for the replies, but nothing helped. I believe it's because the XT2 is so reliant on the Tread App on the phone, that it can't properly process another device like my Satellite Radio. Even though there is the option of pairing another "phone" without the app, it makes no difference in this case; it still connects to the Radio's cradle as a headset, which of course, does not work.
