Dim screen
Bear
Been liked: 3 times
Dim screen
Post by Bear »
The screen of my Zumo 595 seems dim compared to my Zumo 350 and Nuvi 2959. Is it replacable by a user familiar with digital electronics?
Has liked: 110 times
Been liked: 253 times
Re: Dim screen
Google it, and check youtube. That's where I learned just how simple it is to replace a nuvi 780 screen and digitizer. I got a pair of each new plus a little tool kit to do it from China for $16. This extended the life of my nuvi by several yrs.
MSTOCK27370
Has liked: 15 times
Been liked: 36 times
Re: Dim screen
Post by MSTOCK27370 »
Bear wrote: Thu Nov 09, 2023 5:58 pm The screen of my Zumo 595 seems dim compared to my Zumo 350 and Nuvi 2959. Is it replacable by a user familiar with digital electronics?
Before you start dismantling your screen, try changing the map Theme. You can switch themes, which will change map colors and could make the map brighter and easier to read.
viewtopic.php?p=13538#p13538
This link should - hopefully - take you to the last entry of a post I had, where I uploaded a map theme, Auto Club 04. Give it a try, you can always return to the theme you have now if you don't like it. I went through about 2 or 3 edits of the theme, so if you grab the file, make sure you take the last one.
Michael S.
Trinity, North Carolina
Has liked: 130 times
Been liked: 102 times
Re: Dim screen
I've changed the map themes, which helps, and turning off the 3D map layers can also assist in making things more visible. And, zooming out past 3 miles dramatically increases the background grey darkness, and that doesn't seem to be adjustable in the themes.
