Hi, XT recently messed up the entire route and I was forced to re-enter the entire route.
Importing took a long time and when I tried previewing the route, I didn't see anything. Is there anything unusual here? Thank.
Re-enter all routes
- Has liked: 426 times
- Been liked: 933 times
Re: Re-enter all routes
First of all, welcome to the forums.
uHmmm. Can you clarify :
Re-enter the entire route.
I assume you mean that you had to transfer it into the Zumo from some external source ? If so, what did you use ?
But if you mean that you had to re-import the original that you had already transferred - can you tell us where the route was transferred to - internal storage or SD card.
There is a difference in the way that the Zumo treats gpx data, depending on how it was transferred and where it was transferred to.
Eg. Sometimes I use Basecamp and with the XT attached, I can send it direct to internal storage.
Eg. sometimes I create a gpx file, and use a file explorer to place it on the SD card.
What happens next is very different. I know what it does in each case, but it would help me to work out what has happened in your case if you could add those extra details.
