Powered mount
Nortoncommando
Powered mount
Post by Nortoncommando »
When I charge the XT with the cord in back it charges up and works normally. It will not charge on the powered mount, goes dim and shuts off when the battery runs down. the pins on the powered mount are showing 12V. If it is off and I plug it in to the powered mount it turns on, but it ins not charging.
any thoughts, recommendations?
MF
raesewell
Been liked: 18 times
Re: Powered mount
Post by raesewell »
The voltage coming from the mount should be 5 volts.
Has liked: 74 times
Been liked: 193 times
Re: Powered mount
You should never see 12V at the XT mount pins. The small box on the cord should be dropping the 12V vehicle voltage down to 5V.
Has liked: 58 times
Been liked: 46 times
Re: Powered mount
Is there a mix of XT and XT2 here? The XT mount is 5V. The XT2 mount is 12V.
The XT2 can be used in an XT mount, with some limitations due to insufficient power.
The XT can not be used in an XT2 mount.
willbird
Re: Powered mount
Post by willbird »
I just opened a new XT2 yesterday, the little device in the cable says that it outputs 5VDC ??
Bill
Rofor
Has liked: 172 times
Been liked: 79 times
Austria
Re: Powered mount
Post by Rofor »
Are you sure that you've opened a new(!) XT2?
Only a Zumo XT(1) should have a 'little box' in the cable - it transforms the normal 12V of a motorbike to 5V. The Zumo XT2 normally uses 12V and could also handle the 'old' mount of the Zumo XT(1) with 5V...
Bye, Robert :)
willbird
Re: Powered mount
Post by willbird »
Great question :-). I was posting from work and when I got home I looked, and it is an XT not an XT2 :-).
twowheelstom
Has liked: 114 times
Been liked: 40 times
Re: Powered mount
Post by twowheelstom »
Nortoncommando wrote: Mon Aug 19, 2024 12:20 pm If it is off and I plug it in to the powered mount it turns on, but it ins not charging.
the motorcycle mount power cable is not charging your XT because I think the amps are not high enough
https://support.garmin.com/en-CA/?faq=4 ... tab=topics
When the zūmo XT IS connected to the motorcycle charging mount, the current draw is Input: 10-30V, 1.5A (max) Output: 4.8-5.5V, 1.5A.
I think the XT battery charges up when amps are above 2.1amps like when using a 2.1amp usb wall charger
to my knowledge. that 1.5A output on the motorcycle power mount is just to power the XT screen and not high enough amps to charge up the internal XT battery
willbird
Re: Powered mount
Post by willbird »
I have mine plugged into a normal PC USB port and the battery seems to be fully charged when I unplug it.
Rofor
Austria
Re: Powered mount
Post by Rofor »
@twowheelstom - on our motorcycle holidays we normally drive from 9:30am to approximately 04:00pm through the southern italy alps. When we start, the Zumo XT is fully loaded and when we stop and i disconnect the Zumo XT, it's also fully loaded...
So i think it already charges also when in the motorcycle mount...
@willbird - Hopefully not on the bike? It's no good idea to use the 'normal' usb port of the Zumo XT for loading on a running bike! The vibrations likely will harm the usb port after time because of the vibrations...
Bye, Robert :)
