396 won't power up - SOLVED
lather
Been liked: 5 times
Post by lather »
I connected my Zumo 396 to my Windows PC to load some routes with Baecamp. It was showing as fully charged. I disconnected to turn it own to import the new routes but it won't power on. I also tried it in it's cable on the motorcycle and nothing.
Has liked: 380 times
Been liked: 823 times
Re: 396 won't power up
Try holding in the power button for a long time........ > 30 seconds. That can work on other Zumos
I don't know if you can disconnect the battery on a 396, but I have had success with that on a 590.
Fxwheels
Has liked: 26 times
Been liked: 30 times
Post by Fxwheels »
jfheath wrote: Sun Dec 04, 2022 3:17 am Try holding in the power button for a long time........ >
That.
lather
Been liked: 5 times
Post by lather »
That worked, thanks!
lather wrote: Tue Dec 06, 2022 3:24 pm That worked, thanks!
Brilliant. You are now a qualified Garmin expert.
