396 won't power up - SOLVED
I connected my Zumo 396 to my Windows PC to load some routes with Baecamp. It was showing as fully charged. I disconnected to turn it own to import the new routes but it won't power on. I also tried it in it's cable on the motorcycle and nothing.
- Has liked: 380 times
- Been liked: 821 times
Re: 396 won't power up
Try holding in the power button for a long time........ > 30 seconds. That can work on other Zumos
I don't know if you can disconnect the battery on a 396, but I have had success with that on a 590.
Brilliant. You are now a qualified Garmin expert.
