Can XT Bluetooth to Rider and Pillion Packtalk Bold Units?
Has liked: 424 times
Been liked: 241 times
Re: Can XT Bluetooth to Rider and Pillion Packtalk Bold Units?
Peobody wrote: Mon Apr 10, 2023 8:51 pm
Stu wrote: Mon Apr 10, 2023 7:54 pm I have recently changed the way I pair my phone, gps and Cardo
Normally it was phone to cardo and gps to cardo. This resulted in very clear phone calls and phone calls would mute others and others couldn't hear me too
I now have my phone to the gps then gps to the cardo. This allows others in the group hear me when I am on the phone but not hear the conversation from the phone
I am going to be pairing back to the first option I think
It's a catch 22. I like having the phone connected to the gps, both for traffic alerts and for the visible notice of texts and calls. Based on what I have seen, the Cardo is supposed to mute phone calls so group members don't hear them. Enabling the "Parallel Audio Streaming" feature breaks that. Do you know anything about that feature and where to enable/disable it?
I'm pretty sure you still can
Pair the phone to the GPS and the Headset then on the phone settings go in to bluetooth and turn off phone calls for the GPS but keep in on for the cardo
I am also pretty sure that doing it that way allows the gps to still show who is calling etc
Edit: just checked and it wont work properly taking calls through the headset and trying to get it to show who is calling on the XT. But you can pair to both and have calls through the phone and still use traffic and texts but not for calls
Has liked: 432 times
Been liked: 952 times
@Stu
Just a thought - I don't even know if you have the choice, but is your XT regarded by the Cardo as a GPS, or as a phone ?
@jfheath I pair it as a gps
The XT behaves like a phone when paired. You can dail from it, see who's calling access the call list, contacts list, get text messages. All of the spoken stuff in and out is processed by the XT.
I wonder how the cardo would behave if the XT was paired as a phone ? Maybe other features would change. I don't know, I have never come across these before. - but I've a feeling that I will in the very near future. Hence my interest.
I note in the manual some of the controls - which you might want to do while riding - mention that an LED flashes a particular colour. Not very informative when riding, I thought. I thought that holding in a push button for two seconds to mute the DMC intercom was a bit much. At least you don't have to take your eye off the road to do it. 2 seconds is a long time.
Has liked: 120 times
Been liked: 122 times
My experience is with Sena units, but perhaps it applies. Pairing as a GPS results in mono sound and lack of controls for music, among other shortcomings. It is a feature that was designed when less fancy GPS units needed simple protocols to communicate directions. It assumes that you are also pairing a phone as a phone and so you don't need music or stereo or voice dialing for your GPS. That has changed. Pairing as a phone allows stereo sound and all the controls you would find on a smartphone.
Has liked: 148 times
Been liked: 455 times
jfheath wrote: Tue Apr 11, 2023 10:59 am I wonder how the cardo would behave if the XT was paired as a phone ? Maybe other features would change. I don't know, I have never come across these before. - but I've a feeling that I will in the very near future. Hence my interest.
I have had my XT paired as a GPS and as a phone. I didn't notice any difference in behavior either way. I have not experienced the shortcomings mentioned by @danham when paired in GPS mode. I can voice dial ("Hey, Siri" works), music is in stereo, music controls on the XT work (music is on the XT, media audio is disabled for my phone in the bluetooth settings on the XT). AFAIK, I am paired in GPS mode now and am setting in my recliner with my helmet on, testing these functions. I can not figure out a way to verify the GPS mode but it was only a few weeks ago that I was re-settng-up everything trying to get voice navigation commands audible by pillion. It was paired as phone prior to that so I'm certain that I paired in GPS mode to test. It worked.
Edit: OK, I just discovered that incoming texts are not being displayed and that the media audio option for my phone will not stay turned off. Hmmm.... I wonder if the phone IOS update done two days ago has affected anything. Geez, it's always something!
I'm sure you noticed that I said my Sena experience might apply to Cardo. Here's more detail, which might still help with Cardo issues.
When you pair to a Sena using GPS, it only allows HFP Bluetooth, which stands for Hands Free Protocol. That is a mono protocol that allows some control of a phone, but not all features. If you pair the GPS as a 2nd phone, you get HFP and A2DP, which stands for Advanced Audio Distribution Profile and is stereo.
