Problem Installing Maps to PC
wingrider.steve
Post by wingrider.steve »
I have updated my XT to the latest mapping but when I try to also install the mapping to my PC the install fails.
Any ideas on how to solve this would be appreciated
Has liked: 103 times
Been liked: 133 times
Re: Problem Installing Maps to PC
The first thing that I can think of. Did you have Basecamp and or Mapsource running while installing? Basecamp/Mapsource should not be active.
Has liked: 343 times
Been liked: 368 times
wingrider.steve wrote: Fri May 19, 2023 7:16 pm I have updated my XT to the latest mapping but when I try to also install the mapping to my PC the install fails.
How does it fail? Any error messages?
wingrider.steve
FrankB wrote: Fri May 19, 2023 7:52 pm The first thing that I can think of. Did you have Basecamp and or Mapsource running while installing? Basecamp/Mapsource should not be active.
No, Basecamp and Mapsource not running!
wingrider.steve
sussamb wrote: Fri May 19, 2023 8:40 pm
I get a red band across the top of Garmin Express with "There was an error installing the update"
wingrider.steve
sussamb wrote: Sat May 20, 2023 5:48 pm See this FAQ
https://support.garmin.com/en-GB/?faq=G ... C0ULxHR2T6
Thanks, I will be away for the next few days but will take a look at this when I get back.
wingrider.steve
I finally got around to try and sort out why this was happening!
It seems the problem was caused by the XT being connected to my phone, I disabled the Bluetooth and then was able to install the maps to my PC.
Has liked: 369 times
Been liked: 780 times
I'm not suggesting that what you say isn't correct, but my phone is always connected to my XT when it is turned on. I've never had problems installing maps to the Zumo or to the PC. .......
..... except .....
When I ask Express to do all of the updates, or a number of updates at the same time. That nearly always results in one or more failure.
I always update just one thing at once. I never have wi-fi set up on the XT
I'll keep an eye on that next time I use Express - make sure phone and XT are actually connected, see if I can replicate it.
JohnnyRidesAlone
Been liked: 10 times
Post by JohnnyRidesAlone »
TBH the XT is so flaky when it comes to connecting to the PC. I have had this issue and I used the time honoured and scientific rule of do the same thing over and over until it works.
