I have updated my XT to the latest mapping but when I try to also install the mapping to my PC the install fails.
Any ideas on how to solve this would be appreciated
Problem Installing Maps to PC
- Been liked: 4 times
Re: Problem Installing Maps to PC
How does it fail? Any error messages?wingrider.steve wrote: ↑Fri May 19, 2023 7:16 pm I have updated my XT to the latest mapping but when I try to also install the mapping to my PC the install fails.
I get a red band across the top of Garmin Express with "There was an error installing the update"sussamb wrote: ↑Fri May 19, 2023 8:40 pmHow does it fail? Any error messages?wingrider.steve wrote: ↑Fri May 19, 2023 7:16 pm I have updated my XT to the latest mapping but when I try to also install the mapping to my PC the install fails.
Thanks, I will be away for the next few days but will take a look at this when I get back.sussamb wrote: ↑Sat May 20, 2023 5:48 pm See this FAQ
https://support.garmin.com/en-GB/?faq=G ... C0ULxHR2T6
I finally got around to try and sort out why this was happening!
It seems the problem was caused by the XT being connected to my phone, I disabled the Bluetooth and then was able to install the maps to my PC.
- Has liked: 427 times
- Been liked: 934 times
I'm not suggesting that what you say isn't correct, but my phone is always connected to my XT when it is turned on. I've never had problems installing maps to the Zumo or to the PC. .......
..... except .....
When I ask Express to do all of the updates, or a number of updates at the same time. That nearly always results in one or more failure.
I always update just one thing at once. I never have wi-fi set up on the XT
I'll keep an eye on that next time I use Express - make sure phone and XT are actually connected, see if I can replicate it.
..... except .....
- Been liked: 10 times
TBH the XT is so flaky when it comes to connecting to the PC. I have had this issue and I used the time honoured and scientific rule of do the same thing over and over until it works.
