XT Mounted on Road Tech 660 Mount?
bynumpi
Post by bynumpi »
I currently have a Zumo Road Tech 660 mounted on my Harley Davidson. I'd like to upgrade to the Zumo XT and want to know if I can utilize the existing mount? The attached picture from the Road Tech Zumo mounting kit instructions looks like it will work. My understanding is that the bolt pattern is pretty much a standard, and since both units are Garmins, I thought it would work. Has anyone here tried this or have thoughts on the matter?
thanks,
bynumpi
Road Tech Zumo 660 Fairing Mounting Kit.pdf
660 mounting kit schematic
(632.11 KiB) Downloaded 706 times
TripleThreat719
Has liked: 5 times
Been liked: 31 times
Re: XT Mounted on Road Tech 660 Mount?
Post by TripleThreat719 »
Part G in your drawing is what I am assuming you are calling the mount, not the Garmin Specific Cradle.
If so, then yes... All Garmin Mounts/Cradles utilize the standard AMPS Mounting Bolt Spacing, so the XT Cradle will bolt up to part G in your diagram.
bynumpi
Post by bynumpi »
Yes. Part G will stay mounted on the motorcycle fairing. I'll need to do a little rewiring, but sounds like it will work. Thanks for the feedback!
bynumpi
biglew55
Has liked: 45 times
Been liked: 8 times
Post by biglew55 »
That HD part should have been called the AMPS Fairing Mount Adapter. They were selling the z660 at the time so they used that instead.
rtaylor1
Post by rtaylor1 »
bynumpi, Did the mount work out? I’m wanting to do the same.
bynumpi
Post by bynumpi »
Yes. The mount worked perfectly.
rtaylor1
Post by rtaylor1 »
On your post you said you would need to do some rewire, am I correct to assume that you just “slid” the XT-2 power supply into the mount, basically just replaced power cord. No modifications?
bynumpi
Post by bynumpi »
Yes. That is correct. The rewiring I had to do was behind the fairing.
HDRIDER
Post by HDRIDER »
Can someone tell me where the plug from the GPS interface module plugs into? I'm installing this on my 2007 Electra Glide standard
