595 App for routes
Panman
Wales
595 App for routes
Post by Panman »
Is there a gpx App for an android tablet that will load routes to my 595 on the go?
advnzer
Been liked: 8 times
New Zealand
Re: 595 App for routes
Post by advnzer »
i think you need to tell us exactly what you want to do.
Has liked: 424 times
Been liked: 241 times
He wants an app for an android tablet that will allow him to create routes and then transfer them to the zumo
Has liked: 110 times
Been liked: 253 times
Can't you simply use BaseCamp on a tablet? I dunno, I've never owned one.
rbentnail wrote: Tue Mar 05, 2019 9:13 am Can't you simply use BaseCamp on a tablet? I dunno, I've never owned one.
A Windows tablet yes a android one no
I have a tablet that runs Windows and can run basecamp on it although the internal memory is small so installing maps is a pain!
Seldano
Post by Seldano »
You could try the MyRoute app. It's made by the guys who did Tyre. Don't use the app myself (still use Tyre on the desktop), but I've got mates that use it and they seem to like it
Cheers
Rob
Breezly
Has liked: 22 times
Been liked: 32 times
Post by Breezly »
Quick answer is yes, but I would caution you that you need to have an understanding of the differences between via points and shaping points, how they behave in routes in your GPS and whether the app you select is capable of creating shaping points.
Also be aware that any of the apps will be using different maps than what you have installed on your GPS and you may end up with routes behaving differently on your device than what you had planned.
A few the come to mind:
MyRoute
Kurviger
Locus
OSMAnd
