595 App for routes
595 App for routes
Is there a gpx App for an android tablet that will load routes to my 595 on the go?
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
Re: 595 App for routes
He wants an app for an android tablet that will allow him to create routes and then transfer them to the zumo
- Site Admin
A Windows tablet yes a android one norbentnail wrote: Tue Mar 05, 2019 9:13 am Can't you simply use BaseCamp on a tablet? I dunno, I've never owned one.
I have a tablet that runs Windows and can run basecamp on it although the internal memory is small so installing maps is a pain!
You could try the MyRoute app. It's made by the guys who did Tyre. Don't use the app myself (still use Tyre on the desktop), but I've got mates that use it and they seem to like it
Cheers
Rob
Cheers
Rob
Quick answer is yes, but I would caution you that you need to have an understanding of the differences between via points and shaping points, how they behave in routes in your GPS and whether the app you select is capable of creating shaping points.
Also be aware that any of the apps will be using different maps than what you have installed on your GPS and you may end up with routes behaving differently on your device than what you had planned.
A few the come to mind:
MyRoute
Kurviger
Locus
OSMAnd
MyRoute
Kurviger
Locus
OSMAnd
