Allow me : !! John (moderator)
Handlebar Controller for XT2
Re: Handlebar Controller for XT2
Playing, I have installed everything according to the scheme that was shared on the forum. Trying different options. The feel of the buttons is very good.
- 20241123_143610.jpg (371.95 KiB) Viewed 9590 times
- 20241123_132003.jpg (421.93 KiB) Viewed 9590 times
- 20241123_113903.jpg (381.99 KiB) Viewed 9590 times
Thanks for posting those @turbo19 .
Please excuse me (ab)using my moderator privileges and copying the images to twist them through 90 deg).
It looks like a really good fit on your bars.
Mine will be here next week - but Its a surprise. It'll be an even bigger one when the cables come 5 weeks later. I'm not in a rush though. The entire fairing will have to come off to replace the wiring harness.
- Francis
- Has liked: 13 times
- Been liked: 18 times
- Contact:
For restrict voltage for remote controller, may be enough simple circuit with Zener diode?marcparnes wrote: Mon Nov 18, 2024 4:25 pmExcellent point. Mine comes today and I'm going to use it.jfheath wrote: Mon Nov 18, 2024 2:17 pm Maybe the Remote Controller needs a more restricted voltage of 10 to 12V than the varying voltage that is provided by a direct connection to the battery ?
Marc
BMW R1200 ST
- Francis
- Contact:
It occurred to me ... can somebody to measure the voltage in Y-cable in micro-USB connector for the Remote control? Maybe there is only 5V in the cable from XT2 to remote controller, then the new power cable would be unnecessary.
BMW R1200 ST
The problem I had was with the plug. I couldn't find a similar one. I didn't dare cut the Y cable (to put in another plug).
I have several electronic friends, and they have sent me plugs that are similar but never the same. Maybe some manufacturer makes them exclusively for Garmin.
If you find the male plug needed to feed the Y cable, please tell us what model and reference it is
- Francis
- Contact:
I'm lazy, I'll take the path of least resistance. I won't be afraid to cut it.turbo19 wrote: Sun Nov 24, 2024 10:37 pm ... I didn't dare cut the Y cable (to put in another plug) ...
BMW R1200 ST
Just answering a question on FB page. Someone had ordered a cable that I didn't recognise.
Santa brought me my handlebar controller and high current cable and the necessary Y adapter. Clever of him to work out what was required.
But looking back at the Garmin page to see which cable this chap had bought - and a new one is now listed on the Garmin site.
This cable was not there when I ordered my setup at the end of November. There is no price showing at present and it is says that it will be available in 4-7 days. (Current date 28 Dec 24).
And it is shown as being compatible with the Handlebar Controller, with the Tread GPS and the XT2 GPS.
And it matches the diagram in the instruction manual. And it has a new mount for the XT2.
That is really irritating. I've modified my post of 9 November to alert anyone else that it is not necessary to buy two expensive cables when one expensive cable is all that is needed. I've included the same image in that post as well.
Just thought that I'd check the tiny screws that hold the connector in place. They need a very tiny precision star head screwdriver. Fortunately I have one. It's a Torx T5 head that fits.
I have the same problem. I have ordered the return of the other 2 cables (accepted by Garmin), and I am waiting for the price of this new reference. Disastrous marketing.
Price for Spain:jfheath wrote: Sat Dec 28, 2024 8:25 am Just answering a question on FB page. Someone had ordered a cable that I didn't recognise.
Cheaper than the other 2 cables, and with the new support included. This now makes more sense.
Chopperbob
- Has liked: 21 times
- Been liked: 4 times
late to this discussion but when you order the package from Garmin in the Netherlands, both the cables are included:
So it appears that both are needed???
