BMW NAV
Scarecrow
Been liked: 26 times
BMW NAV
Post by Scarecrow »
Me Again sorry
does the BMW Nav VI use Mapsource
I'm doing some route and one of the group has one so I need to know if I need to do them in Basecamp also.
Thanks in advance
Del
Has liked: 371 times
Been liked: 380 times
Re: BMW NAV
Don't need either, just send him a .gpx file to copy to the GPX folder of his Nav VI
Scarecrow
Re: BMW NAV
Post by Scarecrow »
sussamb wrote: Thu Aug 27, 2020 4:58 pm Don't need either, just send him a .gpx file to copy to the GPX folder of his Nav VI
HA HA HA HA.
Sorry for laughing but he does well to turn it on I had to do his updates and install the routes for him on his old 590
He has no chance with the new BMW unit
Re: BMW NAV
OK, well in that case you can do it for him? The bottom line is that MapSource will only work with devices in mass storage mode and his Nav VI by default will be in mtp mode. There are ways to change it but if you have both MapSource and BaseCamp just copy and paste the route from MS into BC then send it to his device.
Scarecrow
Re: BMW NAV
Post by Scarecrow »
Great thanks for that just didn't want to end up as his place with the routes on the wrong map :D
Scarecrow
Re: BMW NAV
Post by Scarecrow »
Just a thought as I'm a bit of a newbie to basecamp :oops: does it work ok with 590 and 595 units
if so I could just use basecamp for all units
Re: BMW NAV
Yes, BaseCamp works with pretty much every Garmin device.
