Me Again sorry
does the BMW Nav VI use Mapsource
I'm doing some route and one of the group has one so I need to know if I need to do them in Basecamp also.
Thanks in advance
Del
BMW NAV
- Has liked: 3 times
- Been liked: 26 times
Re: BMW NAV
HA HA HA HA.
Sorry for laughing but he does well to turn it on I had to do his updates and install the routes for him on his old 590
He has no chance with the new BMW unit
Re: BMW NAV
OK, well in that case you can do it for him? The bottom line is that MapSource will only work with devices in mass storage mode and his Nav VI by default will be in mtp mode. There are ways to change it but if you have both MapSource and BaseCamp just copy and paste the route from MS into BC then send it to his device.
