Garmin Drive App - Battery Drain
copacetic
Been liked: 3 times
Post by copacetic »
Greetings again,
I installed the Garmin Drive app on my Android phone and it all works fine.
While not using Drive, I noticed my battery draining faster than normal. I turned off "Allow Background Activity" for Drive and it still remains the app that uses the most power of all apps - and it's not even in use. This makes no sense to me.
So I uninstalled it. I will only install if going on a long trip when having text messages, email, and weather radar, etc. is handy. The basic functions I need for local riding work fine without Drive.
Has anyone else noticed the same battery drain issue?
Thanks
simoncrewe
Has liked: 46 times
Been liked: 37 times
Re: Garmin Drive App - Battery Drain
Post by simoncrewe »
My Huawei phone warns me the 'Drive' app is using a lot of power & lets me 'force stop' it.
Mod note: please use the reply rather than quote button when responding to a long post immediately above yours as unnecessary long quotes just clutter up the thread. I've deleted the quote in this instance. Thanks
Has liked: 343 times
Been liked: 368 times
copacetic wrote: Sun Apr 18, 2021 12:12 pm While not using Drive, I noticed my battery draining faster than normal.
Wow, just checked mine and found the same. Must try and find out why.
auke54
Has liked: 5 times
Post by auke54 »
Just checked. Drive for IOS connected to Zümo XT: no problem.
XT (SystemSoftware 6.30)
There is a battery management setting in the Apps settings, unchecked the second one in the list of two to see if I notice any difference.
Rofor
Has liked: 153 times
Been liked: 65 times
Austria
Post by Rofor »
Think you confound Garmin Drive with the older 'Smartphone Link' - there is no option for battery management in the settings of Garmin Drive...
Bye, Robert :)
Oops, yes you're right, I was looking at the smartphone link. Assumed Drive was the same given the comment in the OP about turning off background activity.
copacetic
Been liked: 3 times
Post by copacetic »
I tried to Force Stop the Drive App but it ignores my request to stop. The only option I have is to uninstall it. This is on Android 11.
