Greetings again,
I installed the Garmin Drive app on my Android phone and it all works fine.
While not using Drive, I noticed my battery draining faster than normal. I turned off "Allow Background Activity" for Drive and it still remains the app that uses the most power of all apps - and it's not even in use. This makes no sense to me.
So I uninstalled it. I will only install if going on a long trip when having text messages, email, and weather radar, etc. is handy. The basic functions I need for local riding work fine without Drive.
Has anyone else noticed the same battery drain issue?
Thanks
Garmin Drive App - Battery Drain
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
Re: Garmin Drive App - Battery Drain
My Huawei phone warns me the 'Drive' app is using a lot of power & lets me 'force stop' it.
Mod note: please use the reply rather than quote button when responding to a long post immediately above yours as unnecessary long quotes just clutter up the thread. I've deleted the quote in this instance. Thanks
Wow, just checked mine and found the same. Must try and find out why.
Think you confound Garmin Drive with the older 'Smartphone Link' - there is no option for battery management in the settings of Garmin Drive...
Bye, Robert
I tried to Force Stop the Drive App but it ignores my request to stop. The only option I have is to uninstall it. This is on Android 11.
